Hi, thought I'll share my experience here about the funky rear wheel spacing on my 2006 Yakuza Aniki.
Bike came stock with a rear 135x10 quick-release hub. Always had a PITA installing and removing the wheel because I had to compress the drop-outs a lot.
After changing out for a solid axle, I measure the frame and find out the rear spacing between drop-outs was in fact 142mm. So I re-space my hub and now I have a nice 142x10 solid axle rear end which is much stiffer and lot easier to work with. I guess this was made to allow some kind of compatibility for 142x12 rear spacing along other IH frame that used the same rear swing arm or something along this ?
Or could I weld on some adapters and turn my frame into a 142x10, but using the QR system of a 142x12mm hub, not making the frame 142x12, but using 10mm axle instead. That would be awesome ! But I guess you would have a hard time welding something solid on aluminum drop-outs and figure out a way to make it work...
Well. A few pics. Hope this helps other people in the same situation
Edit : Pics to come soon
