Hello all!
I ride a C'dale 29er in a 2x9 setup (Cannondale Hollowgram SI cranks)
I have ordered a SC Tallboy, and am hoping to go with 2 chainrings in the front.
I've ordered an XX crankset (166 Q-factor for appropriate clearance) and the chainrings are okay according to SC for clearance (the 39/26 setup).
However, I didn't have QUITE enough $$$ to go full XX, so I'm hoping to run XO rear, XO twist shifters. I have an XX front derailleur and an X9 front derailleur from other projects to cover my front derailleur bases.
Here's my question--can I run a XX crankset with a 9-speed drivetrain (XO rear, XO twist shifters)?
I asked my LBS and three online retailers (big, reputable ones) and here are their answers:
1. Yes, no problem, if you use an XX front derailleur
2. No, can't do it. You have to go XX all the way.
3. Yes, no problem, although you might have to play with your front derailleur to adjust the stops (makes sense)
4. No, don't even try it.
So, hoping you have some input here--thanks in advance for your help!!!
