Sounds like it is time for a full bleed and new pads. Mine are superb, have been running them for two years at least.
Reds.Gold or red pads?
To me the levers feel great, I have only ever run SRAM brakes though.Sounds like it is time for a full bleed and new pads. Mine are superb, have been running them for two years at least.
Reds look to be organic, gold look to be sintered. IME, sintered is more bite and power all the time, despite what a few say.Reds.
Interesting, I have done about 10hrs of riding on them now after I re-surfaced them. Would have assumed they would have bedded in by now.I have the same set up. They have awesome stopping power, have you bed them in good yet? Those ceramic pads do need a little aggressive breaking before they bite.
Try following the instructions for bedding in the pads (see instructions for your brakes/pads). It normally takes only a few minutes to do it correctly, you should feel the power come in ... just riding will not do it, more likely to create long term poor performance.Interesting, I have done about 10hrs of riding on them now after I re-surfaced them. Would have assumed they would have bedded in by now.
Just don't throw the old pads out until you've concluded this issue.pads could be contaminated with oil. Try a new pair of pads and see (i know, you have to spend)
You do not neccesary need new rotors but cleaning with brake cleaner and new pads . There is no known method of cleaning of contaminated with oild pads it just don'r work- pure waste of timeSounds like contamination, especially if the noise is a goose-like honking and it disappears or changes when the rotors are wet.
New pads and rotors time. Cleaning isn't a substitute if you want the brakes to work 100%.
How much did you clean the rotors before installing new pads?I purchased the bike used, so likely used rotors.
