1 - 20 of 38 Posts
bike rider
What does the M971 front derailleur weigh? I'm talking about the "traditional style", high mount, "down-swing" with 34.9 band clamp. I already checked starbike.
Super Moderator
My old-school XTR FD-M952 weighs a whopping 112g, and shifts much better- thanx to the independent differential plates.
Super Moderator
The Most Reliable Part on My Entire Bike!
f3rg said:
That's the very same one I have (just had to go double-check)! 113g and nearly a decade in service... like butter.
Lelandjt(OP)......try to find one one these awesome front derailleurs, on eBay. We cannot say enough good things about it. It absolutely blows away the latest and greatest XTR FD- and it weighs just a hair above a road FD.
Sorry for the dirty pic(I ride over 100 miles/week!)....but this is by far the MOST dependable part on my entire 19-pound weight weenie hardtail. The independent differential plates literally GRASP your chain and places it on the next chainring- it's truly a stroke of genius........too bad Shimano stopped production of it, in 2000.
The ONLY drawback is that the FD is extremely tricky to adjust properly, due to it's unconventional construction and design. Good thing most LBSs are well-versed on this part, and will set it up perfectly. I'm keeping mine forever.....it's THAT GOOD!!!
Super Moderator
Curmy said:
Can a bottom pull one be adopted for the top pull in that model. I only found a bottom pull one on Ebay.
Unfortunately, they cannot. You need to keep looking, they are really worth it. You need a top-pull specific XTR FD-M950/951/952 or M960. Good luck!
Not to jinx it, but I had a couple. The cage pivot pins were their proverbial Achilles' Heel, and I suspect that's why Shimano went back to a rigid cage. At least all the top-swing XTRs still have alloy cages.
Banned
well - not quite: actual DAs weigh 78g ;)
I'm using mine with 2x9 with great success.
By the way - those older XTRs weigh just 105g if you put some aluminium bolts.
1 - 20 of 38 Posts
