1 - 9 of 9 Posts
I Have Gnarly Potential
Is it possible to use XTR disk brakes with King hubs? (with a different 6 bolt ISO disk or something)
And if so in your oppinions is that better then getting XTR centre lock hubs?
I already rode that
If you can go King then why not? Unless its to save $$ by going XTR hubs.
As long as the rotor is 160mm or whatever your bike is set to with the caliper then it should work. XTR is not centerlock specific, thats just what Shimano came up for to be different and lighter.
And easier.
I am not a fan of centerlock, but as a Mechanic, I like that there are no more stripped torx head bolts, and C/L uses a cassette tool.
Cl
is very cool! Much better than torx bolts. However, only Shimano (and eventually Galfer) makes a rotor to fit CL hubs (the DT adapter works great however).
To answer the original post, you can't use just any 6 bolt rotor with XTR brakes (Hayes rotors for example, does not work because of the difference in the Hayes and Shimano brake track). You're best off with a Shimano 6 bolt rotor.
I already rode that
Thats incorrect there. I used Hayes/Avids/tektros 6 bolts and never had any issues with brake track. With the round Tektros and the like the brake track is pretty big itself. Shimano rotors are generally a bit thinner then the rest.
Oooops, you're right. My bad. I meant to say that you can't use Shimano rotors on Hayes brakes. Well, at least you can use it for a month or so until the wider Hayes pads start vibrating against the Shimano rotors annoyingly... I have successfully used Hayes rotors with my XTR calipers...
1 - 9 of 9 Posts
