Yup, it's the cold. I have xt's and they act the same way in the cold.
Thanks. That will save me some time trying to bleed them when they don't even need it.pelts79 said:Yup, it's the cold. I have xt's and they act the same way in the cold.
"Supposed" to being the key word here. I have experienced first hand the symptoms described here with new mineral oil when the temp was in the upper 20f degee range.mnigro said:Still do a bleed. I reread the article and mineral oil is not supposed to be affected until 0 degrees unless there is a lot of water in the system. DOT is good to about -25 F before issues start.
This, along with all the other fuss, headache, PITA maintenance etc. is why I run BB7's. With good housing and set up correctly they are hard to beat. And the price...damn.pelts79 said:"Supposed" to being the key word here. I have experienced first hand the symptoms described here with new mineral oil when the temp was in the upper 20f degee range.
Me too... the oil is not the problem.pelts79 said:"I have experienced first hand the symptoms described here with new mineral oil when the temp was in the upper 20f degee range.
Actually it's DOT fluid that's hygroscopic not mineral oil...mnigro said:I am by NO means an expert on hydro's. In fact, I run BB7's on both my bikes. But, FWIW, I just read an article about this. Supposed to be very low temps before the oils are affected. DOT at a lower temp than mineral oil but I think it was something like 0 degrees (maybe lower?) before mineral oil really starts to have issues.
However, the one issue with Shimanos/mineral oil systems is that it absorbs water over time. If you have not bled the brakes in a while it might be good to do so as fresh oil should have less H2O and thus be less effected by the cold temps. This is also why DOT systems are affected at lower tmeps than mineral oil systems.
This article was in Mountain Bike Magazine I think.
