All shimano hydraulic brake parts are mix and match swappable (apart from rotors, at least) as long as you can get the hoses to mate up.29ERCAT said:I have a set of 2008 xtr non servo wave levers and a set of 2008 xt calipers,I know the hose lines are the same.Has anyone tried this set up,and are the two compatable....:thumbsup:
pimp....thx for the info,what model xtr caliper are you using,some of the reviews talked of sticking piston and set up issues on the xtr 975pimpbot said:All shimano hydraulic brake parts are mix and match swappable (apart from rotors, at least) as long as you can get the hoses to mate up.
I currently run LX dual control hydro lever/shifters with XTR calipers using bulk Shimano hose with shimano straight-through fittings at the lever end with Hope banjo fittings at the calipers. Works great. I love the feel of the XTR brakes... not as much as the Hope Mono Minis, but I still really dig this setup.
