I thought I would have no problem with this setup on my singlespeed. Especially liked the fact that the Dura-ace bottom bracket weighed 40 grams less than the XTR!
The spindle length was okay for my chainline and It seemed like the spline interface was good enough. I had some issues with loosening crank bolts, and now the drive side crank arm is loose on the splines.
Has anyone else had a problem with these two components mating? Did I just ride a little too long with loose crank bolts?
I am replacing the XTR 950 cranks with some 952s. Do you think I will have the same problem?
Also, I noticed the XTR 950 bottom bracket is lighter than the 952. Anyone aware of the difference? Do you know where I could get my hands on a 950 with a 112.5 spindle?
