After following Highdells amazing guide on repacking bearings I have run into a bit of a problem.
I seem to have completed all the steps shown there and have the wheel running nice and smooth. Then I put it back in the frame and tighten up the quick release and now the disc rotor is tight against the calliper mount and the wheel cant turn. Its almost like it's too far over to the non drive side now. If I have the non drive side cone in a position on the axle where the wheel can turn (when in the frame) then there's a load of up and down, side to side play in the axle. The bearings are new and the hub itself aint that old (so no real wear) and was working well on this bike before I got to grips with it.
I have about 5 threads of the axle sticking out on the drive side but from looking at the guide pics I end up with more threads showing on the non drive side. Its almost like the hub is now thinner.
And I have installed everything back on that came off:madman:
Essentially the wheel runs real smooth but when put in the frame and the quick release is tightened the disk is tight against the caliper mount. Any idea what I might have done wrong?Is there anyway that anything could have moved thus allowing the loss of 5mm
I would much appreciate as much help/ideas that anyone can give
Cheers in advance:thumbsup:
