X2 :thumbsup:lgh said:2. Because of the variability in bearing size, it is best to replace them all at the same time with good bearings from the same batch. If that single bearing you put in is too big, it will cause more harm than good. If it is too small, it won't do much good at all.
Get 'em from your LBS - You want a higher grade (25 or 30) of bearing for use in hubs than are going to be sold at your local hardware store.knutso said:Hi
I bought an xt rear hub for $10 cuz it was missing a bearing, otherwise in good condition
Is my jerk-off lbs my only hope for getting a single replacement ball bearing ?
