Put the rear wheel in the air and push the der with your hand while spinning the cranks. Does it move normally when you push it in to the big cogs? If so,.....
If it was a cable problem, it would hang the same going the other way. The der spring wouldn't be able to overcome the cable friction.
That's what I would try.
