So had my brakes for 2 years now. I over filled them once and had some fluid squirt out the over flow valve. Since then they have leaked out that port. Never had any issues other than just put the bowl on top and topped it up 2 times a year. I read an other thread on here others had this issue and it eventually stopped.
Mine hasnt stopped so i took the whole brake apart. Seals seemed fine, everything was super dirty and covered with gunk. Cleaned it all up and then decided to blow into the hose end and see if there is a noticeable leak. Yup... could hear a leak out the valve.
So used my compressor and at low psi i blew into the hose end and could hear air rushing out. Did this a few times and then blew into the hose end with my mouth and no air rushing out noise. Success?
Put the lever back on and instead of forcing up from the caliper i did the bowl and just squeezed the lever until the air bubbles stopped coming out. Lever is nice and firm....
We will see if this solved the issue. If not im going to have to buy a new lever cause this is annoying.
