With these cranks there are two bolts that use a 8mm (I think) to attach the cranks to the bottom bracket. Then there is a spacer and a cap that go on each side. The caps have two small holes in them, but my crankset didn't include any type of tool to tighten these up.
What are you guys using to tighten the caps (kind of look like dust caps) up? If they are just going to fall off then I won't even bother putting them on.
Thanks in advance...
