Back story: I'm a long-time XT brake fan. I've used them on my last two builds and I've had zero issues with them, I love the feel and the stopping power. I bought a 18' Carbon Comp last year and it came with Sram Level brakes on it. Not a fan. Switched out the rear with XT (haven't changed the front yet). Thus far, it has been an exercise in frustration:
The bleed didn't go as smoothly as past XT bleeds I have done. I've had to do a few "mini bleeds" to get them as firm as they should be. Mission accomplished. However, the grip between the pads and the disc leave A LOT to be desired. You can't lock up the rear if your life depended on it (not that I go around locking up the rear, just an illustration of how weak they are). Oh, and they are howling, something I've never had an issue with XTs.
I'm not sure what kind of pads the Srams came with, but I'm using metallic pads. I didn't clean the rotors when I did the original install. I thought that was the culprit, but I have since put in brand new pads, and I've resurfaced the rotor with emory cloth, and cleaned it with alcohol. Still, no bueno.
Here are some suspects:
I'm not using the Shimano brake bracket. The Camber has two bushings on the rear brake mounting posts where the Shimano bracket/adapter would be. I didn't see the need in installing it, I figure the bushings serve the same purpose.
After all of my "mini bleeds" the pads are really close to the pads. Not rubbing, mind you, but really close, like 1mm.
Despite my efforts to clean those rotors, maybe I didn't get them thoroughly clean. With new pads, and a sanded rotor, you'd think you could rule those things out, but I guess not.
What say you, mtbr nation? Any ideas which way to turn? Thanks!
