1 - 2 of 2 Posts
So, I just received an OEM set of 2010 XT disc brakes and it appears they are European spec, with the front brake on the right side, etc. Will I need to bleed the brakes and replace the olive, etc. if I just remove the hoses from one side to the other?
Any tips when doing this?
Never trust a fart
Maybe and maybe.
I've swapped just hoses before with out them leaking or needing re-bled. But I've also swapped hoses and an entire re-bled had to be done.
Only way to know is to try it.
Only tip is don't get fluid on the brake pads/rotors.
1 - 2 of 2 Posts
