I just put a few drops of silicone lube on the lever pivot.
Sent from my SM-N950U using Tapatalk
I only did it this once because of the issue. Looks like I'll be buying a replacement lever or try to fix this one.Is this something you do on a regular basis or just this one time because it was sluggish? I don't spray anything on my bike except for lube on my chain and on my pedals springs, all spraying stuff elsewhere does is attract dirt. Most likely your seal is blown out/expanded, it happens, not sure why, as not common among the brakes, but have had it happen on one of my 10 sets of Shimano's, only solution is new seals, work around is to take it out, clean and leave it to dry out a bit.
How old are your brakes? You might be able to warranty them? I think xt brakes have a 1 or 2 year warranty...good luck.I only did it this once because of the issue. Looks like I'll be buying a replacement lever or try to fix this one.
