My wife complained that her front brake was not working as good as it used to. She also had a flat tire. So we turned the bike upside down to change the tube. Bike was upside down for maybe 10 min.
After being upside down I tried her brake and the level went all the way to the bar!!!
So I decided to bleed the brakes. After bleeding them I tested them and noticed that it seemed like they were still not right. (Did not go all the way to the bar). So I bleed them again and got MORE air out!!!
At this time I'm wondering what is really wrong. I noticed that when pumping the brakes after bleeding it seemed like oil was comming out from the reservoir. The "leak" seemed like it was between the "silver top" and "black bottom". (Circled in the attached photo)
I took it to the LBS and they said everything was fine. I dont believe them. ;-)
What is the construction of these reservoirs? It looks like the torx screw on top holds the top on. I tried to tighten the torx but it seems tight.
Is there a seal in there which is leaking? What can I do to fix these? Do we need to replace the lever/reservoir?
The leak stops after a while but the brake seem soft and I'm 99% sure there is air it again.
Sent from my LG-H871 using Tapatalk
