Bontrager Duster rims tick all your boxes. Similar level of 'burl' to the Arch, little bit wider, killer tubeless.
Currently available in silver, 32h.
Nice. Thanks, Mikesee. It looks like they're genearally only available through Trek/Bontrager dealers. Do you offer them?mikesee said:Bontrager Duster rims tick all your boxes. Similar level of 'burl' to the Arch, little bit wider, killer tubeless.
Correct, and yes.JST169 said:It looks like they're genearally only available through Trek/Bontrager dealers. Do you offer them?
I'd think you could get them to inflate with just tape and valve, but I'd also expect burpage from that setup when really getting after it. The Bontrager TLR strips are the bomb--not sure why you'd run these rims any other way.JST169 said:To run them tubeless, is the TLR strip mandatory or can the NoTubes tape and/or strip be used?
I think it's ~115kgf but I've found that these rims don't (long term) like that much tension. I build them to ~105kgf as an average/max and they seem to last longer that way.JST169 said:Do you know the max recommended spoke tension?
But a little too flexy given the OP's specs. I just had a couple spokes/nipples fixed and had my bros Salsa wheel trued yesterday and the shop was commenting on these rims being pretty light duty with straight gauge spokes and alloy nipples, Said they'd be better setup w/double butted/brass nipples. Specially for a heavier rider. Another ride buddy had them and could stand next to bike with one leg on crank and have the wheel fold underneath him, would spring right back into place. Needless to say he replaced them shortly after. :skep:bloo said:i have seen some pics of some silver Salsa rims in here somewhere they looked fancy and wish I had known about them before i built up my current wheelset.
He could have them built them up by now for you in the time he's given on advice.JST169 said:Great information and suggestions. Thank you.
I think I'll look into the Dusters a bit more. The Salsa Delgado Race rims sound too flexy, and I've always heard the Velocity rims are made from a rather soft alloy or minimal profile, allowing them to be damaged more easily.
Mikesee, do you offer the rims separately or only built up?
Jeremy
Velocity Blunt is a nice XC wider rim (28mm wide) that converts easily with the Bontrager Rhythm plastic strips and comes in silver. It's not a polished silver though. 489g per rim.JST169 said:I'm looking for silver tubeless (or easily tubeless compatible/convertable) rims. They'd have to be 29er rims and in the same category as the Arch (XC, not superlight, not overly burly). I'm 165 in the buff, probably 175 ready to ride. I ride a rigid 29er SS (disc brakes) on the rocky, rooty, sometimes unfriendly trails of southeastern PA. I'm not particularly hard on wheels, but I did not have luck with NoTubes 355s a handful of years back. The Arch is about the lowest level of durability I'm looking for.
Any suggestions? Wider than the Arch is OK, but I don't want narrower. I'm not a weight weenie. Tubeless compatibility is a requirement. I currently use Nevegal/Rampage, and plan on going to an Ardent and/or Conti (X King or Race King).
I emailed NoTubes and they said they're not planning on any silver rims.
Thanks for your help!
Jeremy
second the Blunts.BruceBrown said:Velocity Blunt is a nice XC wider rim (28mm wide) that converts easily with the Bontrager Rhythm plastic strips and comes in silver. It's not a polished silver though. 489g per rim.
Anyone have experience with both Blunts and Dusters? Am I offbase in my thinking that Velocity's rims aren't generally as strong as, say, the NoTubes or Dusters?moschika said:second the Blunts.
Yes (just built one yesterday for a friend).jager7 said:Do dusters have the offset spoke holes?
Which NoTubes rim are you comparing to the Blunt?JST169 said:Anyone have experience with both Blunts and Dusters? Am I offbase in my thinking that Velocity's rims aren't generally as strong as, say, the NoTubes or Dusters?
I've seen a lot of wheelsets built with Blunts around these boards!
Jeremy
Bruce, I'm not directly comparing the Blunts to the NoTubes rims. I am currently riding Arch rims (self-polished) and was looking for a rim similar in strength and intended application (rigid SS on rocky/roots/techy trails). The Duster and Blunt surfaced as probably the best options.BruceBrown said:Which NoTubes rim are you comparing to the Blunt?
New Blunt SL tubeless just announced here. It will be narrower and lighter than the current Blunt.
