So what's the difference between the XLT, 2.0 and 3.0 frame beside the rear shock and paint? Is it the exact same frame?
I beleive they are the same frames just different parts specs.Trailhappy said:So what's the difference between the XLT, 2.0 and 3.0 frame beside the rear shock and paint? Is it the exact same frame?
What he said.See65 said:I beleive they are the same frames just different parts specs.
Ha - You're right!Trailhappy said:Thanks, I thought they might use different tubesets on the lower end models. But maybe that's for the other models.
The Jamis XLT frames are constructed as follows:Descalzo said:Ha - You're right!
After reading your post I checked their site. Seems the 1.0 uses 7005 for the full frameset, while the 2 & 3 use Scandium for the main & 7005 rear triangle/swingarm.
Sorry for the mis-info![]()
