1 - 17 of 17 Posts
My XL-SL is scheduled for 'early january' arrival... I will certainly put some pics up when it shows... In the mean time I second the 'show your xl mojo' idea, anyone else getting their XL-SLs in the next couple days?
here is mine
xl frame
red ano links w/ ti bolt kit
k force light cranks
xtr shifters
xtr shadow r der
xtr front der
magura marta sl brakes
mavic crossmax slr wheelset
easton ec90 post
race face next bars
sella italia flite ti rail seat
You know my steez...
toddmcgill said:
here is mine
xl frame
xtr shifters
xtr shadow r der
xtr front der
easton ec90 post
race face next bars
Sweet! Weight? Why not cut the steerer down some?
Hey Todd,
thanks for the pics, very interesting for me, as I am 6'6"-6'7" and interested in a Mojo.
Can I ask you a q: how tall are you and what length and angle of stem do you use? Do you have any difficulty in keeping the front wheel on the ground on steep climbs?
Best,
Jever
Hi!
Mine
Frame Ibis carbon XL frame
Fork RockShox Pike 454 U-Turn Coil 95-140 PopLoc
Headset Cane Creek IS8
Rear Derailleur SRAM X.0
Front Derailleur Shimano XT
Shifters SRAM X.9
Brake levers Avid Juicy 7
Brakes Avid Juicy 7 203/185
Hubs Hope Pro II
Cassette Shimano Deore XT 11-34
Rims Mavic 819 UST
Tires Schwalbe Nobby Nic 2.25"
Cranks Shimano XTR
Bashguard Ethirteen Supercharger
Bottom Bracket Shimano XTR
Stem Syntace VRO
Handle bar Syntace VRO low riser
Grips Ergon E1 enduro grips
Saddle Specialized Rival II
Seatpost Maverick Speedball RM
Pedals Shimano 540
Greets MPI!
jever98 said:
Hey MPI, could you pls post how tall you are and what stem setup you use? I am trying to figure out my best setup, without being able to test ride.
Jever
Hi Jever!
I am 189cm (~6,2) ja 95kg (~209). Stem is a fully adjustable Syntace VRO stem (55-105 mm) with 20 degrees rise. http://www.syntace.com
Syntace stem needs a Syntace bar because of the construction of stem. So you cannot use any other bars with it.
Greets MPI!
MPI -- I see that you have a speedball on your bike and that you are a similar height... How is that working out for you? I have to have the XL frame due to having most of my height in my inseam (36).
I have been considering getting one of those. Despite the extra half pound it seems like a great option to open up performance on everything but the long haul where you need pedal efficiency above all else.
hey i am 6'6" tall 36" inseam 210 pounds
i am currently running a bontrager 120mm 17 deg rise stem off of my fisher hifi,
as you can i am sure see from my photos my seat post is pretty well extended making my center of gravity a bit high, which as you guesses seems to make the front end a bit light on hills and in corners, i can overcome this by leaning foward and lowering my center of gravity,
which addresses bunnys question , i recently dropped my stem to see if that would help get me over the front end more helping weight the front,
it did to some extent,at the cost of some hand numbness,
i havent decided if this is where it will stay so i havent trimmed it,i am trying to find a longer stem with a decent weight and maybe less rise that i can play with before doing any trimming.
my current weight is 26 pounds which a little heavier than i expected but ohh well.it was 24.4 with tubless maxxis ignitors, but i didnt like the grip of dusty leafy trails.
Hi Todd,
thanks a lot for the information - very interesting.
I was thinking of running a 110mm 10 degree stem, and to use a fork that can be collapsed easily for climbing - for example the Pace RC41. On my current bike, a Bionicon Edison (same length frame, adjustible geometry) I find the ability to collapse the fork very useful for climbs.
In terms of seat post - I am toying with the idea of getting a 400 or 420mm gravity dropper. With the collapsible fork and a quick drop post I hope to have a combination that would make the bike work for me well.
Btw my trouser inseam is 36", leg length 99cm (usually ride with top of saddle at something like 83 or 88cm above bottom bracket)
May be some other tall folks wanna join in and share experience?
Jever
Hi!
Speedball increased my speed and ability to descent. I can move my body better without hitting ba..s to saddle. Very good product. Little bit sideplay in post but you do not notice it when riding. Saddlepost also needs some maintenance if you ride alot, but it is DIY thing.
Greets MPI!
Just throwing this out there... i LOVED the mojo but at 6'4" with a 37" inseam i knew there were going to be some compromises to make it fit. I demo'ed a 29er and ended up buying it instead. My bike handling is much improved, the seat post isn't ridiculously high, i feel comfortable on the bike etc. The downside is that you have a heavier bike (maybe 4-5lbs)... but it fits and handles better for me than a 26er!
Wow, Mojo XL looks the same as other Mojo sizes. I hate some companies where the large frame looks ugly, its like they just add a longer head tube and doesnt care bout how the bike looks anymore.
Toddmcgill, ur bike looks perfect with those red add-ons.
MPI, nice seatpost, how do you like it and what you think bout the Syntace stem?
Hi!
About Maverick Speedball see a post above. I like a little laidback position and Syntace stem and bar makes it possible. Both are must to me.
Greets MPI!
1 - 17 of 17 Posts
