1 - 4 of 4 Posts
Would like to put a dual crown on an xl highline. Problem is max distance between crowns on 888 is 160mm per Marz website, headtube is 6" (152mm), zero stack upper and lower headsets add 12mm total per cane creek website for a total of 164mm. I've seen pics of Bikezilla's xl with a 888 on it so it seems it can be done. Will it work?
Yeah You can squeeze them on just.You might just be over the recommended distance between crowns by a couple of mm though.I'm using an FSA orbit Z 1.5r.
You could always cut loose and face the head tube down.
Discussion Starter · #4 ·
Cool, good to know it will work. And yeah, I did notice there is a considerable amount that could be removed from the headtube face, but hate to have to do that if not needed.
1 - 4 of 4 Posts
