What size tires will you be running?
Sent from my moto e6 using Tapatalk
FWIW, Continental Race King 2.2s are marked on the sidewall as being for 21mm to 25mm rims. I'm running 17.5mm rims because old school 26" cross country rims are narrow, and there isn't much choice for going wider. No issue going too narrow except not being able to run really low pressures. Performance is fine in corners, and probably better than going wider than the spec due to the edge knob issue.30mm works fine with some 2.25" tires. Some doesn't work because side knobs sit too far inboard by their tread knobs design on 30mm rim.
I ran 25mm Flow EX rims on my Chameleon for XC racing.FWIW, Continental Race King 2.2s are marked on the sidewall as being for 21mm to 25mm rims. I'm running 17.5mm rims because old school 26" cross country rims are narrow, and there isn't much choice for going wider. No issue going too narrow except not being able to run really low pressures. Performance is fine in corners, and probably better than going wider than the spec due to the edge knob issue.
35mm. That wayif you don’t podium you can blame it on the heavy rims.Thank you for all the responses- appreciate it!! Bike's main purposes will be for long distance endurance races. 2.2 tires to 2.4 tires.
