1 - 4 of 4 Posts
mtnjam
Discussion Starter #1
Looks like one of the adjustment screws on my X9 rear derailler came out. I got a new screw from the LBS down the road, tried to put the screw in and there's obviously something missing. Can I get a new threaded insert for the H screw?
Some Assembly Required
Go back and see if they have the "insert". I think its a pc. of plastic and if they have a bad derailluer they can rob it from, you're gold. Maybe the one they took the screw from ??
I notice my high limit screw is way out when adjusted properly and have always wondered why SRAM doesn't give you a shorter screw to keep it from gettin' snagged on something. Guess I could just grind it down. It isn't like it'd have to be heat treated afterwards. :prft:
1 - 4 of 4 Posts
