1 - 5 of 5 Posts
I am looking to go 2x10 on my Anthem 29er. The places I ride are really hard on cranks and I don't feel like destroying an XTR crank (the only Shimano 2x10 option at the moment) The X9 crank looks to be a solid value. My question is this: can I just use that crank with the SLX rear derailleur. I don't see why not, but just wanted to check here. Thanks.
Obsession? Its a Passion!
Yes, you can. Make sure you have dyna-sys shifters as well. Just be sure not to mix chainrings, chains, and cassettes. Dyna-sys is meant to work only with other dyna-sys cogs. (Dyna-sys cassette with Raceface chainrings is a no-no). Go with a SRAM 10 speed cassette to avoid this.
Mix all you want. Shimano, SRAM, RF etc. just match 10 speed with 10 speed.
There's nothing unique or ground breaking about Dyna-Sys. Shimano always says not to mix and match their components and many do w/o any problems. Just make sure you are using 10 speed Shimano shifters with 10 speed Shimano RD. Other than that, mix and match to your heart's content.
Pretty sure the giant uses a shimano press fit 90/92 BB. Only way to fit the sram cranks is to use the gxp version and an adapter for the BB.
Look into the race face double crank, as they make a version for BB92
1 - 5 of 5 Posts
