bigdonut said:
Looking to do the same thing to a 2006 Manitou Nixon Super which is at 6", would like to go to 3" or 4". Any luck?
More information would be helpful for a proper answer (that fork is no longer made (no info available) and with the down fall of manitou in the last few years, many are not familiar or care about the various Manitou models).....
That being said, the basic idea is to add length to the negative spring and take away the same amount of length to the positive (main) spring. All maintou forks that I have ever seen allow access to both springs (whether air or coil) so this is certainly possible.
If the fork is air:
-with an air negative spring, just add more air to the top out and remove it form the positive spring
-with a coil top out/negaitve spring, you need to shim or add to the neg spring. a chunk of PVC works well, or both RS and fox make spacers for this kind of thing that might fit.
For a coul fork:
you need to add to the neg coil spring as above, but you must
also shorten the main spring by the same amount. HTis can be done by replacing the spring with a shorter model spring or (sometimes, with a bit more work) cutting the original spring. Be careful/aware when cutting a spring that you will change the rate (make it stiffer) and also will not have the flat end that it once had...
