Your tall enough to ride 26"s and its a 26" specific bike so stick to the 26's.
(hahah, did i say 26 enough?)
24/26 , the best of both worldsRed Bull said:Your tall enough to ride 26"s and its a 26" specific bike so stick to the 26's.
not if your frame isn;t designed for it.EastCoastHucker said:24/26 , the best of both worlds
nooooooooo!pin-it said:24" wheels are SO 2003.
Thats for canadians.EastCoastHucker said:24/26 , the best of both worlds
24 specific frames means that they're more compact, shorter chainstays and seatstays. 24s accelerate faster, which is good in skateparks since you want to build up as much speed as you can. 24s are usually lighter, and thus easier to flick around. 24s don't roll over stuff as well though.cummings said:okay, for x-mas i was gonna ask for wheels.first i saw some street riders with 24" wheels and thought it would be kinda cool. then some other people said stickin with 26" would be the best way to go. now when i'm ridin at the indoor skatepark (which i'm gonna be doin alot of this winter), i see almost every mountain bike with 24" wheels. i'm gonna be riding pretty much all street, skatepark, and a little dirt jump . also, why do the guys at the skatepark have 24" wheels. is it easier to jump and flick around in the air? i already konw it's easier to manual. if i do switch to 24" wheels, is it hard to make that switch? if it matters, i'm 5'6" and still growing and i ride a 13" kona stuff.
what would he be rolling over in his discrition though?XSL_WiLL said:24 specific frames means that they're more compact, shorter chainstays and seatstays. 24s accelerate faster, which is good in skateparks since you want to build up as much speed as you can. 24s are usually lighter, and thus easier to flick around. 24s don't roll over stuff as well though.
In the event that he decides to use the bike elsewhere too.JBsoxB said:what would he be rolling over in his discrition though?
I run 24/26 and love it too...XSL_WiLL said:In the event that he decides to use the bike elsewhere too.
I'm probably gona get a lot of hate for this, but I run dual 24 Halo SAS wheels on my Kona Coiler, and I love it.
If you do just park and DJs, 24s will be worth it. They DO help you accelerate faster, as well as increased control. And yes, they are lighter. Oneoldman is just a 24 hater. Some bikes just don't feel right running 24s, but I love my Coiler with 24s and it's fine for what I do. I still ride trails, and it doesn't bother me. I do find that I'm spinning out more and mashing in the 3 highest gears more often. The transition is easy. Just swap over your cassette and disc rotors. You'll need new tires, tubes, and rimstrips (obviously). Just be sure that you buy the proper hub spacing and types. If you can get the rear wheel in a 10mm or 12mm stepped down to 10mm bolt-on axle, then it'll be perfect. If you can't, it's pretty easy to change it down the road.cummings said:Thanks for all the replies and the goods and bads for 24" and 26" wheels. I just wanna know if the smaller wheels will help me jump dj's and bigger jumps higher and in more control and be able to flick the bike around better. I don't really care about rolling over things and doing trails cuz that's not really my style. Also, is it hard to make the switch from 26" to 24"?
A lot of the feel is up to the rider. But the Kona should ride well with 24s. It will take some getting used to. I know that I loved the P.series bikes with 24s. The frame is so short and compact, that it just feels right.cummings said:XSL_WILL, you say, "Some bikes just don't feel right running 24s, but I love my Coiler with 24s and it's fine for what I do." Would my 13" Kona Stuff be one of those bikes that just doesn't feel right with 24's or would it be a good bike to make the switch on?
Just get 26"s and leave it at that. May i suggest Sun Ringle 8 tracks. Great wheel for 350 directly from Sun ringle.cummings said:XSL_WILL, you say, "Some bikes just don't feel right running 24s, but I love my Coiler with 24s and it's fine for what I do." Would my 13" Kona Stuff be one of those bikes that just doesn't feel right with 24's or would it be a good bike to make the switch on?
If I do get 26"s, i'll probably be getting Mavic EX729 with something like XT hubs and Holyroller or Hookworm rubber.Red Bull said:Just get 26"s and leave it at that. May i suggest Sun Ringle 8 tracks. Great wheel for 350 directly from Sun ringle.
