Hey,
I have a normal hardtail frame running XT rings (44-32-22) with an SRAM X-Gen front der. Neither I nor my mechanic can get the thing adjusted right so that i get the full spread of gears in the rear without the chain rubbing on the cage in the middle chainring. If its adjusted to get the granny, it rubs when i shift to 8th or 9th. when its getting the high gears ok, the fd cage rubs in the granny.
all other aspects are fine. height of the fd is as per instructions, the cage is aligned with the chainrings when looking from above.
Any help?
cheers,
chuggboy
Any help?
cheers,
chuggboy
