Just got my Romic coil shock from FoShizzle yesterday for my X 5 and downloaded the owner's manual from Romic's site. (Thanks Fo!!) This is my first coil shock, so I'm a little intimidated by the set up. Romic's manual is vague when it comes to setting preload/sag. It says in big letters - "Never use more than 3 full turns of preload to adjust sag." 3 full turns starting from what point? From where the spring is no longer loose on the shock body? Does "3 full turns" mean three 360 degree rotations of the adjustable spring retainer?
Also, does anyone have a chart as to what spring rate one is supposed to use on the X 5 when taking into account the rider's weight? FoShizzle generously sent two springs to me - the 450lb x 2.25 and the 400lb x 2.25. My weight, with Camelbak and all geared up, ranges anywhere from 170 to 185 during the year. Which spring should I use?
