My scale tells me 28.4 lbs.jrm said:Would like to build something in the less than 28-30 lbs catagory. Could you guys post your builds and their corresponding weights. Thanks alot have a good week.
Except for using a Talas, Sram twisters, CK hubs and a BG .2.1 in back and a FA up front..Wobbegong said:My scale tells me 28.4 lbs.
Specs are:
Medium X-5 with quad bearings-fox float w/ propedal
Fox vanilla fork
King headset
Thomson 90mm 5 degree stem
Easton EC70 Monkeylite xc bar
Odi lock on ruffian grips
Thomson Post
WTB Laser titanium rail seat
Avid Juicy Seven brakes
WTB Laserlite disc hubs/ DT Swiss xr 4.1d rims
Sram X9 triggers
XT Front der.
Sram X9 rear der.
04 XT Cranks
04 XT Cassette
Sram PC-99 chain
Schwalbe Little Albert tires
Hey Gonzo - could you email me a photo of your X-5?gonzostrike said:mine's nudging 34 lbs as follows:
medium frame w/ Quad bearings and Romic coil-over
'03 Marzocchi Z1 FR QR20
King headset
Thomson 90x5 stem
Answer ProTaper 2" rise 27" wide bar
SRAM X-7 trigger shifters
Avid SD Ultimate levers
ODI Lock-On Ruffians
Hadley 20mm disc front hub
Avid mech disc 185mm rotor front and rear
Hadley DH 135mm wide, 10mm thru axle disc rear hub
14/15 db spokes, Mavic XM321 rims
Kenda Stick-E Kinetics 2.35 tires
Thomson 410mm post
Hope QR post collar
WTB Rocket V Stealth saddle
SRAM 9.0 11-34t cassette
SRAM X-7 rear der
Shimano XT front der
Race Face Turbine LP Isis 175mm crank arms w/ 34t middle ring, 22t litte ring, BlackSpire Ring God bash ring.
Race Face Evolve FR bottom bracket
Crank Bros Mallet C pedals
Below is a picture from Tuesday's ride.CTRider said:Hey Gonzo - could you email me a photo of your X-5?
Also, what is your weight and what springs oil weight/height are you running in your Z1 - I've got one on my Belair now and I'm trying to get it dialed in.
Mark
