Is that all it weighs?Stans rim tape adds 8g to each wheel. I just taped my wheels a few days ago for the first time. i29 30mm tape. I wouldn't use anything else next time since it stuck great and was easy to apply. Just make sure you clean your rims with alcohol first.
Yep, doesn't way much. Google some YouTube videos. 30mm tape for 29idIs that all it weighs?
I've never actually taped wheels before. Do I just tape it to feel the trough or what? How wide of tape do I buy?
Thanks, I think I'll go with the Stan's.
I could be wrong but I'm pretty sure Stan's says to overlap opposite the valve hold. Anyway I've done it both ways successfully.Disregard the 'bandaid' tape bits. That is me troubleshooting other leaking issues.
Note the overlap at the valve. The red lines are the overlap.
I agree, don't overlap at valve hole. if you do, the valve gasket needs to work against two layers of tape and additional chance of wrinkles, seepage or air loss. overlap but not at the valve ensures the valve and gasket can tighten very well against one layer of tape. with two layers of tape the tighter you go might make the tape slip against itself and wrinkle a bit....I could be wrong but I'm pretty sure Stan's says to overlap opposite the valve hold. Anyway I've done it both ways successfully.
Yep. I do it on the opposite side and it works like a charm.I agree, don't overlap at valve hole. if you do, the valve gasket needs to work against two layers of tape and additional chance of wrinkles, seepage or air loss. overlap but not at the valve ensures the valve and gasket can tighten very well against one layer of tape. with two layers of tape the tighter you go might make the tape slip against itself and wrinkle a bit....
do whatcha want but logic (to me) says one layer at valve hole for simplicity and integrity of the valve and gasket
