1 - 15 of 15 Posts
Has anyone had any issues with their WTB saddles (specifically the Volt) making noise from the underside of the saddle. The noise emanates from from plastic molding where it makes a cracking/popping sound. I can push on the saddle and it makes the noise, although it is not as pronounced as when I am seated and riding. This is the second WTB Volt saddle I have had this issue with. The previous versions of the Volt saddle were fine. I have tightened the small bolts under the seat which run around the perimeter of the saddle which seemed to help a little. I was just wondering if anyone has had issues with theirs as well.
Shartacular Spectacular
I’ve experienced this phenomena as well, then I washed out real bad in a turn two weeks ago and turned the rails of that volt race into something more closely resembling a modern art piece. I’ve since purchased another and it doesn’t seem as noisy... yet...
Discussion Starter · #4 ·
I love the Volt saddle...great fit and light. I'm going to lube where the rails run up and into the plastic molding under the saddle (thanks Carpetbomber!). I think that is exactly where the noise is coming from. Thanks guys, I'll circle back and let you know if it worked. Rubber side down.
Magically Delicious
Over the years, I have experienced multiple creaking/squeaking saddles. I have successfully silenced them, but only temporarily. I have tried silicone spray and liquid drops, Tri-Flow, chain lube, gear oil etc. While all of these have worked, they were all temporary. Once the lubrication intervals increased to being a hassle, I would replace the saddle. I have a decent collection of retired saddles hanging on the garage wall.
Magically Delicious
^^^^ We must be talking about different origins of this creaking. I am speaking of where the seat rails go into the saddle, not at the seat post.
I make this assumption because there would be no practical way to get marine grease into the location I speak of.
1 - 15 of 15 Posts
