Looking for an alternative to Stan's that is commercially available. Any feedback on the WTB and Caffelatex systems? Thanx.
Any ratios to start off with?salimoneus said:Why not just make your own? All components available a local shops, and cheaper. I'm using a combination of the following:
-Mold Builder or comparable liquid latex (arts crafts store like Michaels)
-Green Slime (Walmart)
-PEAK RV Biodegradable Antifreeze (Walmart)
I also optionally add some tiny glitter particles (Glamour Dust from arts crafts store) to assist in sealing small holes.
Works great and you can easily tweak the formula depending on your particular needs and climate.
I don't think I've ever really measured it out, it's sorta like cooking when it's ready you just know lol. But if I had to come up with ratios:Chase1996 said:Any ratios to start off with?
I was actually trying to think of a liquid that has the same consistency but was drawing a blank. I think one of those smoothie drinks is probably close if we're thinking of the same thing, maybe even a bit thinner.Chase1996 said:Thanks!
I have never dealt with Stan's / Caffelatex before...
Is your consistency like milk, or more like a yogurt smoothie drinks ( I realize that's a weird reference)...any known liquid I could measure it against?
The tubeless Slime is better as mtnbiker said, seems to have more particles, but sometimes I mix both types of slime. The tube version of slime does have very small particles that can assist in sealing up the tire initially. Even new tires sometimes have very small pores on the sidewalls that need to be sealed, and the tube version can help with this. If you're only going to use one kind though definitely go with the tubeless.Chase1996 said:I think I'm gonna try the homebrew route. Do you have to use the ATV Slime, or will any work?
There shouldn't be any delamination issues, correct? Also, what are you guys using to put it in with, syringe?
How much are you typically using..similar to Stan's recommendations?
