1 - 4 of 4 Posts
about to pull the trigger on a LDL hub, but id like to use a bolt on axle, or a thru bolt or something stiffer than a standard qr. do i have any options for this hub?
Probably have to call WTB directly , then have to speak to an engineer as that has been my experience w/ WTB hubs. They do offer a Super Duty 135mm x 12mm - interchangable ??? . You may be stuck w/ a QR and if you need a HD hub might want to look elsewhere.
Bump - Are there any updates to this same question. I would like to consider at least going to a 10mm thru bolt. Can anyone confirm an easy way to do this???? I figured with so many different options coming out since the last response to this post, someone might be able to shed some light on the subject.
Can anyone confirm or shoot down whether the NoTubes end caps will work for an LDL Hub?
1 - 4 of 4 Posts
