When I saw this I thought of the WWs.
Review: Wren Sports? ultralight aluminum stem is scary light - Bikerumor
Aluminum bolts should be lighter than ti bolts. You relly can't make a bolt smaller than it needs to be so lighter weaker aluminum wins over heavier stronger titanium. There are some places where stronger is better though.I'm using an 80mm one. The gloss finish on them is amazing, I'm not typically a fan of gloss anno, but these are very nice. The lack of material for the threads on the steerer side is a bit scary, literally there's hardly anything there at all. They also use small M4 bolts, could probably save a few more grams with ti bolts since the ones that came with mine were just anodized aluminum.
Mine are definitely black so I was assuming they were anodized aluminum. I'll check with a magnet when I get to the house today.I'm pretty certain, borderline postive that the bolts are steel
I just checked and they are magnetic. It looks like they are painted, so painted carbon steel, I'm guessing?A magnet wont work on stainless steel...
Jeese man. What the heck is going on here?Excellent observation, Jayem, and one we realized quickly, so all of our stems are now T25. We have maybe 50 of the original spec of T20 out there. We have replaced some already. If anyone has an early Wren stem with T20, send us a copy of your receipt and we will send you a set of T25 bolts.
Russ / Wren
Hmmm...that's weird. Both of my multi tools have both T20 and T25 on them. I have a Ritchey 260 too. Never been a problem with the T20's. You think they're bad...the earlier 260's had 3mm allen heads.One negative I found is that most multi-tools do not have T20 drivers on em, so if your stem loosens up, sometimes due to a real hard hit or whatever, you are out of luck or you need a different tool or an additional tool, which most likely earns you back the weight you saved. My Ritchey stem is also T20. Light, but probably not worth it for this reason.
That's a rarity, I had multiple multi tools and no T20s, I looked for a while before I found one, but it's not what I'd call common, you are just lucky. In any event, it's cool that Wren is giving T25s to people (a common size).Hmmm...that's weird. Both of my multi tools have both T20 and T25 on them. I have a Ritchey 260 too. Never been a problem with the T20's. You think they're bad...the earlier 260's had 3mm allen heads.
Yes, the torque spec is 6Nm. Either T20 or T25. Thanks! RussHmmm...that's weird. Both of my multi tools have both T20 and T25 on them. I have a Ritchey 260 too. Never been a problem with the T20's. You think they're bad...the earlier 260's had 3mm allen heads.
Russ, do you guys have torque specs on your stems? And will that vary between the T20 and 25? I'll be grabbing one of your stems for my son's build for sure. They look awesome.
