My brain does all of this, pretty well too.
My brain does all of this, pretty well too.What do you think? Other things that could be controlled?
Now with our electronic shifters, dropper posts, and suspension controls, it would be nice to have a way to put it together. What I am thinking is a little computer, that only has to do the following:
- If your cadence drops below or above a set range, shift into an easier (or harder) gear.
- (Not sure about this one) If your bike is going uphill and you are peddling (for a certain amount of time) lift the dropper post. (Could also do if you stop pedaling, drop the dropper.)
- When your dropper post it dropped, unlock your suspension. (Could be for amounts ex: 100 percent extended: shock almost locked out, fork locked out. 85-99% full extension: shock is more open, fork is medium. 50-85% full extension: Fork is open, Shock is halfway. Less than 50% extension: Fork and shock are completely open.) You would be able to adjust the amount, or you could just do it in a simpler way (Dropper is fully or partially dropped: Open fork and Shock)
Kobayashi should help. And rich for the trifecta.Sounds like a job for Picard.
Get Varaxis to philosophize about it and go all nihilistic.Kobayashi should help. And rich for the trifecta.
God bless MTBR’s ignore feature.Get Varaxis to philosophize about it and go all nihilistic.
How would it differentiate between if I've slowed my cadence because I'm starting to head uphill versus slowing my cadence because I'm setting up to pedal-kick a drop-off?
LOL, I wonder if I'm even thinking of the right poster?God bless MTBR’s ignore feature.
=sParty
