It should eventually need an oil change, but like a manitou TPC cart, I'd imagine that it would stay pretty good for a long time, due to it not being contaiminated by the springs and stanchions oxidizing.Bikezilla said:This raises an interesting question: if the primary damping is sealed, will there come a time when the fluid in the sealed internal damper needs changing?
I mean, if the rest of the fork fluid gets contaminated and or breaks down over time, what keeps the sealed cartridge fluid perpetually fresh? Is it because it does not have the derbris from the main bushings to deal with and is isolated by a second set of seals and oil bath?
Or do we have to chuck the sealed cartridge annually?
Well, odixation requires exposure to the air, so in the closed cartridge, this may not be an issue, also hard annodized parts can stave off oxidation, so the internals of the damper may not even be subceptible to it if that is the case, but it may not even be an issue due to it being "closed" from the enviroment.Bikezilla said:Oxidation still occurs when submerged and/or coated in oil?
