Worst day of the year - Bud and Lou mounting time!
3894 Views 34 Replies 16 Participants Last post by  Brad Pitted
Season 4, and I grow to hate these tires more each and every year. Yes, I know they aren't made to be tubeless, but eventually they get there. Compared to the 4" Jumbo Jims, these things are just bears. Terrible to mount, slow and draggy.
I keep saying it, but this might be my last attempt to mount before I leave them permanently mounted and buy 29+ for the Spring. Only hesitation is the constant talk of 29+ going away.
Anywho, any magical tricks short of tubes first? The tires are so loose, I'm afraid one side would come off the rim just pulling out the tube. I have bungee cords TIGHT around the tire to hold it flat. I'm not using sealant to mount because of the mess with these tires, using an air compressor, etc.
1 - 20 of 35 Posts
I haven't used those tires in a long time, but I think the general consensus was that it's Lou that's slow.
As for them being loose, can you pull the beads into the bead shelf by hand?
Usually I can use this method and I don't have to be very aggressive with it, as in do ALL of the steps he suggest, but with some fat tires, I do. I find this in general is a quantum shift though from the old days of trying to seat with a compressor and so on.
The most desperate method I know of to mount a tubeless tires is two air compressor nozzles, one to fill the valve and another inserted under the bead while filling the first. This requires two air sources or enough air in the primary source, but it's what some auto shops have to do occasionally. I haven't had to do anything like this since I started using the method below.
Surly did release a tubeless (ready) version of these no? The problem is they last so damn long so it's hard to justify replacing them if it's just an hour of your time that is needed.
  • Like
Reactions: 1
They did, at $120 a pop and unavailable (as most things) these days. Hard to spend $250 for the same tire when these are still like-new.
FINALLY got them mounted, biggest mess and headache to date. Got it mounted with sealant, and just in the action of adding sealant via stem, both sides flopped free and I had to start over. 3 hours or so invested and seasonal swap is done. I'll apply the $250 I'd spend on any new tire towards that 29+ set. 4" JJ not worth this hassle.
Cut your hassle by 50%, leave the tire out back, alone and just mount Bud up front, since it's the one that really matters for control, anyway.
Save more hassle and just leave the rear on.
Traction and control in front, has no off season, and those Schwalbes are terrifying front tires anyway....
whats wrong with putting in a tube first t seat one side good, removing the tube, and then inflating tubeless? Takes like 5-10 extra minutes. I have a really old Lou like you and it stays on fine once I used the tube to inflate one side . . . as long as I dont air down too low, then they can burp.
As expensive as Fat Bike tires are, putting a tube in to get them to seat is no thing to me.
  • Like
Reactions: 2
This is where I'm at. Got a really old Lou that keeps on working, so I just use the tube method and ride it another year from November - Jan *when the ice comes and the Johnny 5 studded goes on). I keep the tire inside when its not on the bike so they last a long time for me.
I honestly don't think the bead would stay set with the tube method. Inflating (Lou) without sealant, it fell off the bead shelf both sides adding sealant through the valve. I think I'll either keep Bud/Lou year round, or add a second set of wheels.
Jumbo Jims absolutely aren't junk in the right circumstances, at least here in the North East. I love how fast they are, add some cushion, great grip over granite boulders and roots, and are light. Going back to my 29er, takes a while to get confidence back at speed.
  • Like
Reactions: 1
I'm a huge fan of the 4.8 JJ as a rear tire. I ride a lot, and ride mainly semi tracked trails that need grip and float. I honesty haven't met any another other riders in my area with more aggressive rear tires where I feel they have an advantage for float and grip. The key for the JJ on the rear is getting the pressure right. Too high and it really isn't very good, though that is the case with most tires.
As for the front, that's where you want something aggressive for control. I still haven't found anything better than a bud up front. It's a really nice combo IME.
Do you ride snow as well? My friend has 4.8 JJ and ridden with me a few times in snow. I notice him washing out in the front compared to my Bud and Lou. If I were to replace my 4.0 JJs, I'd probably go 4.8 to raise the bottom bracket and leave on for snow and skip the worst days.
Sent from my Pixel 4a (5G) using Tapatalk
yeah, I only ride snow with this setup. A JJ would be useless on the front. 100% Bud on the front - I haven't found a better front tire.
The 4.8 JJ on the rear is great. It rolls well and the traction is very good if you get the pressure right. The only time it may suffer is dry fluffy snow where you need to the bigger lugs to reach now and grip something. Those conditions are pretty rare for me.
Hmmm, I have no issue in seating tires on my, by todays standards, classic Rolling Darryl's. Two pair of Bud/Lou and two pair of JJ 4.8 liteskin are no issue.
Much has to do with rim choice as to keeping a bead seated. No UST beadseat in the rim, it's drama time.
This... its a 2 min job to inflate with the the tube in, and then lay the tyre with the loose bead on the down side on top of a bucket, allowing you to pull the bead toward the seat with your hands.
Ideally, yes. My struggle was that Bud/Lou are loose new, and after 3/4 seasons, WAY too loose. Bead didnt stay set even airing down, let alone pulling a tube out. Oh well, survived this round.
Huh? Never had an issue with the original Bud/Lou non-tubeless. Never had an issue mounting any fat tire.
Just put on my Bud and Lou's (tiubeless with orange Seal) been working for 4 seasons. Mine are grip studded and I love 'em. When these eventually wear out i'll buy them again.
I replaced the worn out Lou on the rear with a new Lou last year. Not sure if the original Lou was tubeless, but the new one was marked "Tubeless Ready". I had a hell of a time with sealant leaking at the rim during riding. I thought maybe it was due to dried out sealant residue on the rim, so I unmounted it, cleaned the rim and tire well, and remounted. Still leaked.
I had to put 2 wraps of tape on the rim bead shelf to get a tight enough fit to stop the sealant leaking at the rim during riding. In speaking with others, the consensus was that last winter's batch of Lous fit loose.
That sounds like the OG tire experience I had. Leaked sealant around the bead/rim and made a hella mess with fly paper adhesive residue like scum all over the sidewalls of my tires. Whadda mess. (said in a Duke Nukem voice)
Mendon's got it right. I run Bud on the front year round. Only swap Lou on when the snow falls.
1 - 20 of 35 Posts
