1 - 19 of 19 Posts
I'm looking for Women's baggy shorts that have a longish inseam (about 9 inches), I can't stand when the elastic of the liner is tight around my mid thigh. I've tried the men's shorts, but the fit leaves much to be desired.
Discussion Starter · #3 ·
Has anyone tried the Sombrio shorts. The sizing chart on the web page is a bit odd, it says size medium has a 36" waist and 21" hip width. Is the 21" hip width for one leg?
Freeriding Feline
I have all guys shorts, sorry. I'm a big fan of FOX (anything but the Mid-rangers), I have a pair of Azonics that I really like and a couple of Troy Lee's are on the way as they were on sale. Fox Hucks are my all time fav right now though. For DH anyway...No padding.
I'm assuming that because they specify that the waist measurement is a circumference measurement, that the hip measurement is not. (i.e. measured across laying flat) So it would be 42" at the hip.
My longest baggies are made by Oakley. Bought 'em at Mount Snow at the national last year. Those are the shorts I make sure to wash right away, so they're ready to wear next time I'm ready to ride. I hate it when I fall behind on the laundry and have to wear a different pair :mad:
I think I need some new shorts too. I bought a second pair of tight shorts (is there a fancy term I should know? I'm new to this) a few weeks ago. They were really short, but I liked them OK. Well, I started riding with them and on the first technical downhill spot, I'm up, moving around and my thighs are getting burned by the saddle! Yikes - ouch! So...last night I find out there is such a thing as "spinning specific" clothing. Ah...I think I've got myself some spinning shorts. :rolleyes: Duh...
You might consider baggys with no liners and wear women specific lycra shorts under neath.
Discussion Starter · #9 ·
Thanks for all the help. I think my Ultrasensors under a pair of baggies with no liner is going to be my best bet. I'm going to a shop this weekend that has a ton or really nice men's shorts, so I'll give it another look.
aka red
good luck with the shopping!
my favs are the sugoi gustov's (which are mens or "unisex"). they come with a liner, which i cut out (not fit for women) and use the sugoi rs flex short underneath
http://www.sugoi.ca/consumer/product.aspx?id=2013&srtx=36301U
http://www.sugoi.ca/consumer/product.aspx?id=2064&srtx=38376F.661
there's a women's equivalent, the gusta, but these aren't as long (the liner, which i still cut out, fits great, and i'll use, just not attached) :)
http://www.sugoi.ca/consumer/product.aspx?id=2064&srtx=36300F
cheers,
pd
I just ordered a pair of these. I'll be sure and post a fit-review once they arrive!
black & blue
I just bought a pair of Sombrio shorts, XS size. Great, tough fabric. I find them a little long in the inseam but that's fine for going over padded shorts. They have a liner but no chamois. The waistband is great; several velcro adjustments so you can fit them just right.
You can get last year's design cheaper here:
http://pricepoint.com/detail/15002-586_SMBSC6-1-Clothing-16-Shorts/Baggy/MTB/Sombrio-Women's-Septre-Freeride-Shorts.htm
Well, I got them in the mail today.
I guess fit is about typical for me... too loose in the waist, too small in the hips. I do really like the design and fabric. They have nice zip-vents in the thighs, and adjustable tabs to cinch the waist, but even maxed out the waist is a little too big. Though really, the measurements on the size chart are about right - I'd need a small to make the waist fit, and a large for my butt. Story of my life.
They're so cute I want to keep them though. I'm going to have to get a few opinions...
Discussion Starter · #15 ·
I have the same problem, the waist is usually too big if the hips fit. I really liked the style of those shorts, but the waist measurements seemed awfully large. Do they ride low on your hips or at your true waist.
They are just right height-wise. Low rise enough to be comfortable, but not so low you're butt is visible. Even if they made the adjustment tabs an inch more adjustable, it would be a big improvement.
I ended up racing in them on Friday (Super D), which was fun but I had a flat tire for 2/3 of the course. I had one slide out wreck in practice and the dirt brushed right off, no damage to the shorts. So overall, I like them. :D
Nice Connie!! I dig the pink shorts. I'm thinking about buying a pair too....but not sure if I could get away with the pink on my pink bike. :) Might be a bit too much.
Thanks for the update!! Good seeing you at DV this weekend.
If you notice - they match my grips. :D
1 - 19 of 19 Posts
