What style bottom bracket do you have? Do you hear creaking or snapping when peddling under load?
No, no sounds. The only way I knew something was off was from the chain rubbing the front derailleur in certain gear setups.ThePinkBarron said:Do you hear creaking or snapping when peddling under load?
No clue... sorry. I assume it's Shimano something, but I know there's like... uh, casings and uh, open brackets? Okay, so I really have no clue. Could I send pictures to help, or could you provide things to look for so I can identify the difference? (Seriously, I'm very noob when it comes to this. Sorry.)What style bottom bracket do you have?
I've only noticed it on the second and first, not on the largest. and only when I am in a bad gear combo. But the entire set of chain rings and the guard thing on the outside have a visible (albeit slight) wobble.Does it "wobble" regardless of chainring
No, it's solid.can you actually feel the BB move when if you grip the crank by hand and pull back and forth?
Mkay... I just took off/cleaned/put back on both derailleurs, so I could understand how they could be out of whack. Unfortunately, that doesn't have anything to do with my cranks wobbling. (I checked it out... my gears shift fine. I ain't touching anything until I'm unhappy with them again.)scoutcat said:u just need to adjust your front derailleur. try turning the barrel adjuster a half turn
I'll keep that in mind. Means nothing to me, unfortunately.OK, you have a sealed cartridge square-taper BB
Nah, I'm pretty sure this isn't the case. I tried taking the cranks off about three months ago, not knowing that whole area doesn't come apart without special tools. Everything seemed to be screwed in there quite well.My guess is that either:
a) you have a slightly loose crank
Well, that's not too shabby. Would this be something I'd just have to have the LBS people do? Or would you recommend I just get a crank puller and bottom bracket tool and figure it out myself? (I see that you mention it, so it's got to be at least a slim possibility...b) The spindle is bent [...] new BB ~$20 for your current model IIRC, but might as well upgrade to a BB-UN72 or something - I think they're ~$35?
You could have the LBS do it, but I find working on your bike much more rewarding - plus you'll have the tools for later AND it's dead-simple to pull cranks and do the BB.Kelly Mo said:... Would this be something I'd just have to have the LBS people do? Or would you recommend I just get a crank puller and bottom bracket tool and figure it out myself? (I see that you mention it, so it's got to be at least a slim possibility...)
EDIT: My husband just pointed out that we got the bike in '06, not '05. Dunno if that makes a difference, but figured I'd correct it anyway.
Yes they are. No I won't. Cuz after that what's to stop you from making fun of the flower basket on the front, and then what next? No more handlebar tassels? :cryin: Sorry, this is how I roll... til I get new pedals.ThePinkBarron said:Those arent cages on your pedals are they? Please remove those pronto.
I will send you some free SPD style clipless pedals if you remove the cages. Those things are just asking for an accident.Kelly Mo said:Yes they are. No I won't. Cuz after that what's to stop you from making fun of the flower basket on the front, and then what next? No more handlebar tassels? :cryin: Sorry, this is how I roll... til I get new pedals.
As for the BB:
I think I'll try doing it myself. Unfortunately, I need to wait til the hubby gets home to find out where he hid the crank puller, and soon after we're flying home for about a month. So I'll probably get to it some time in August. That'd also allow us to pick up the parts in the States, where things are a bit cheaper overall anyway.
