Hi. Recently i got some problems with my bike. Basically the problem is that when braking my front wheel wobbles like mad. I also noticed that my front wheel and rim got pulled to the left (towards the disc brake direction). I checked and realised the skewer had came loose. I tightened it back, making sure its rly tight without it coming loose again.
However, during the journey back home, on the road , the wheel still vibrate and wobble slightly under braking as well, this time the skewer is still tightened, not loosened as in the previous case, while the vibration and shaking isnt that severe as the former one as well.
What are the possible causes? Loose headset? Faulty headset? Rotor warp? Disc caliper severely misalligned?
Bike specs : Scott Aspect 2008. Currently using Rockshox Recon 351 coil U-turn fork. Using disc brakes (Shimano mechanical stock) and A2Z 160mm rotors. Using A2Z Titanium Skewers.
