1 - 12 of 12 Posts
We went over what tires we were using for street and DJ but what about the beads your using....I'm thinking about running a 2.2 Halo TwinRail in the back and a 2.35 Kenda SmallBlock8 in the front. Any preferences on beads or even tubeless? Also, will I loose any street-ability switching from a hollyroller to a smallblock8?
Think of it this way, a kevlar bead is designed so you can fold the tire( ie carry a spare on a trail) and so they are lighter( think spandex XC guys), neither are really necessary for Dj's, as it is generally simple enough to carry a spare tire in the truck and light weight is well, up to you I guess.
to answer the last question, i don't think you will lose any street ability by switching to the SB8. i will be making the exact same switch as you pretty soon. the 8's roll so fast and can hold high pressure. the side walls on the 2.1 that my friend loned me are pretty thin, but for a front tire it should be fine. i think he has a light weight compound version or something. still, he has only gotten one flat with it..
ya, I would recommend sticking with a wire bead for DJ'n. Tubeless is nice, but I dont think its what you want.
oh, and UmbrousSoul, your avatar made me crack up
I run composite-beaded WTB MutanoRaptors 2.4 and jump 3-4 times a week without any problems...
IMO, bead shouldn't make that big an impact as far as durability goes... It's all about tire pressure.
As to answer the OP's question... you're not losing anything by switching to a SB8. One of the best tires for street/DJ/park and will probably stick just as well, if not better, on concrete/asphalt than a holy roller.
Yeah, the SB8 has so many working edges at any time its bound to be great for jump and urban. I've heard they are crazy for pump tracks too due to their fast rolling.
I would stick with a wire bead tire. If you're just doing street and DJ you don't really need to lighten up your bike for epic rides. It'll prevent you from pinch-flatting when you're doing street riding, so I would stick with wire-beaded tires.
1 - 12 of 12 Posts
