1 - 8 of 8 Posts
Look what arrived via UPS today!
'09 DWL Turner Sultan, L, Raw
Both my first 29er & my first Turner. A huge thanks to Alex at Cycle Progression in Austin, TX. Great to deal with, even with me currently living in MA.
I'm still in the process of assembling the build kit, but everything should be here by early Feb. if the I-9s arrive as expected. More details to be added here as the build progresses.
Nice to see another '09 Sultan in MA already! I have to say you're a very patient man if you can wait six weeks to get it built, but it's probably worth it for the I9's. You must be able to ride through much of the winter over there by the coast, no?
The raw looks good; did you get a frame weight?
Discussion Starter · #3 ·
I'm going to try to take it in to work Friday and weigh it there. I'll post the numbers then.
Yeah, near the coast I can ride sometimes in the winter . . . though the trails can be icy, especially after these storms. I've yet to try ToT or Otis (I only moved to MA in 2007, from AL), but they'll probably be where I try this thing out first.
Discussion Starter · #7 · (Edited)
Update . . . Build complete! 1st ride today, somewhere on Cape Cod. Build Specs:
Main purpose: Fun
Trail terrain: New England singletrack
Frame Size & Color: L, Raw
Rear Shock: Fox RP23
Fork: '09 Reba Team 120mm w/ Maxle Lite
Brakes: Hope Tech M4/Tech X2 183mm/160mm
Shifter: X.O Trigger
Cranks: Raceface Next Carbon
Front Derailleur: XTR
Rear Derailleur: X.O
Cables: Nokon
Pedals: Eggbeater SL
Stem: FSA OS-99
Handlebar: Raceface Next SL
Seatpost: Thompson Masterpiece
Saddle: Selle Italia Prolink Lite Gelflow
Bottom Bracket: Raceface X-Type
Chainrings: Raceface Team
Cassette: XTR 11-34
Headset: Cane Creek 110
Grips: ODI Rogue
Front Tire: Mountain King 2.2
Front Rim: Stan's Flow
Front Hub: I9 Enduro 20mm TA
Rear Tire: Mountain King 2.2
Rear Rim: Stan's Flow
Rear Hub: I9 Enduro 10 x 135
Future changes: Scrub Components Rotors, Ti Bolts, Joplin R?
Rider Setup
Weight: 155 lbs.
Height: 5' 10.5”
Build pics attached.
1 - 8 of 8 Posts
