1 - 4 of 4 Posts
Its my old rear Axl from my Demo 7. All the specialized site says its a; Specialized thru axl for the specialized hub that it came with. It's 135mm but I dont know if its a 12mm or not
Discussion Starter · #2 ·
Hunting Deep into the Specialized threads it looks like its a 10mm thru axl so it should fit on the normal DT frame
Measure the diameter. If the axle is 10mm in diameter and you have horizontal drop outs it should fit.
If its 12mm it will not with the DT 12mm axle system.
Those look like standard QR dropouts on your Specialized. That axle should work with the Specialized hub on the Delirium with QR dropouts. If you have upgraded to the 12 x 135mm thru axle dropouts for your Delirium, then it comes with the correct axle and just needs a hub designed for the 12 x 135mm standard.
1 - 4 of 4 Posts
