1 - 4 of 4 Posts
· Registered
Please help me figure out if a longer dropper will fit. My goal is to have the saddle lower at full compression. Previous 150mm posts were too tall at full extension but the Loam post has adjustable travel.
Bike: medium 2018 Evil Wreckoning LB
Current post: 125mm BikeYoke Revive
Looking at a 150mm PNW Loam post.
If it’s too tall for my inseam I should be able to reduce travel to fit, and the lowest position would be lower than my current post, right?
· Registered
Hi Nat, We have a great tutorial that will help you measure your bike to find out if the 150mm Loam will work in your Evil.
Here is the link >> How To Size A Dropper Post
Yes that is correct on the travel adjustment. If your collar to rails measurement is not quite the best fit for the 150 you can reduce the travel in 5mm increments to get it just right.
Hope that helps!
· Registered
Discussion Starter · #3 ·
Hope that helps!
Thank you for replying! I went ahead and got the 150mm Loam dropper and it fits perfectly without needing to reduce the travel at all. I took it on a ride this morning and really like it. The sale price was too good to pass up!
1 - 4 of 4 Posts
