Im running a set of road triple Rotor cranks in my Jet9,30/39 & removed the large outer ring & they fit fine.mvi said:I measured several combinations , but does anybody know if a 39/30 (without the 52 ring) shimano triple will clear the joke?
And the crank setup recommendations on the Niner sitemuzzanic said:Im running a set of road triple Rotor cranks in my Jet9,30/39 & removed the large outer ring & they fit fine.
But as Lynx said you would need to check your Q factor
156mm Q-Factor will fit in terms of crank arms, but the chainstay/yoke clearance area for the granny ring and the middle ring will be the determining factor of how close you can get. Check this thread, and you'll see that even with the largest recommended 2 x 10 crank from SRAM (26/39) - some are having chainstuck issues. The same may or could occur with the cranks you are wanting to run. In any event, I wouldn't hesitate to install some zip ties around the yoke area to keep that chain at bay. Pictured in that thread.mvi said:I measured several combinations , but does anybody know if a 39/30 (without the 52 ring) shimano triple will clear the joke?
The Rotor crank has a fully adjustable chainline and a unique bottom bracket solution. Whether it works says nothing about conventional road triples.muzzanic said:Im running a set of road triple Rotor cranks in my Jet9,30/39 & removed the large outer ring & they fit fine.
