....I know these tires are huge (bigger than your average 2.25) so I thought I'd best ask before buying.
thanks
feel the gin
thanks
feel the gin
NuMexJoe said:Shy, I ran one on my '00 Salty and it fit, but barely. I'm sure you've read that the big Geaxs can be a bit wobbly until you get them seated just right, and I had to be particular about that, plus be diligent in keeping my rim true. That said, it worth it, as the Sturdy, despite it's weight, is the best rear tire I've ever used. And strangely, even though I understood that the Salty & the X-5 use the same rear triangle, I had plenty of room when I moved the tire & rim over to the new '04 X-5. Maybe Sherwood massaged the rear triangle design a bit over the years? Go for it; I got mine thru Larry for a very good price.
- Joe
Was your 00 A bushing Salt? If so, then yes when the switch to Bearings was made the stays were made a bit wider for fatter tires.NuMexJoe said:Shy, I ran one on my '00 Salty and it fit, but barely. I'm sure you've read that the big Geaxs can be a bit wobbly until you get them seated just right, and I had to be particular about that, plus be diligent in keeping my rim true. That said, it worth it, as the Sturdy, despite it's weight, is the best rear tire I've ever used. And strangely, even though I understood that the Salty & the X-5 use the same rear triangle, I had plenty of room when I moved the tire & rim over to the new '04 X-5. Maybe Sherwood massaged the rear triangle design a bit over the years? Go for it; I got mine thru Larry for a very good price.
- Joe
I fit a 2.4 WTB Mutano with ease in my rear stays. Actual width 55mm casing 57mm knobs.******* said:...Is the Sturdy exclusively a rear tire?
Thanks for the input
Feel the gin
Ciclistagonzo said:I fit a 2.4 WTB Mutano with ease in my rear stays. Actual width 55mm casing 57mm knobs.
Conti Vertical Pro Casing 53mm, 58mm knobs clears easily as well.
So find out what the Sturdy's actual mm measurements are and you can tell fairly easily if it will fit. Basically anything under 60mm ultimate width appears to clear quite easily. Shiggy's site is a great reference for this.
-A
they didn't make much ado. Just considered it refinement of the frame.NuMexJoe said:Yep, that'd be the difference. Guess Ventana didn't make much ado about the change, but my '04 has plenty of room. It was tight enough on my Salty that I could easily make the tire rub when I was standing in the saddle.
- Joe
jayoutside said:Mike-
I saw a few of your posts on this board before - I ride a Salt and live in Cville as well - Eric told me about you. I run a Sturdy and it fits with plenty of clearance. Feel free to send me an email at "Jayoutside AT hotmail DOT com" - would be cool to hook up for a ride one day
Jay
I'm running Sturdys on both front and rear with good success and clearance.******* said:...thanks for the input. Are you running Sturdies front and Rear or did you go with, say, the Blade up front?
Which "Eric" are we talkin' bout? Frankly, I'm surprised we never met before.
I'll drop ya an email.
