Correct me if I'm wrong but, I think the shock has already moved to the 8.75" x 2.75" variety on the new frame so that you get the full 7" of travel from the get go!???woodyak said:
Correct me if I'm wrong but, I think the shock has already moved to the 8.75" x 2.75" variety on the new frame so that you get the full 7" of travel from the get go!???woodyak said:Does anyone know if the new DT will support running the longer stroke shock to get that extra travel? What was the geometry and travel amount with the longer shock? I remember that it had to be run in the slackest HA setting but I don't remember the other details. Has anyone here tried the DT with the longer shock? Impressions?
That be the V-tach shock - Pretty sure the DT is slightly shorter i2i / stroke.Dominator13 said:Correct me if I'm wrong but, I think the shock has already moved to the 8.75" x 2.75" variety on the new frame so that you get the full 7" of travel from the get go!???
