Eville140 said:
The SRAM 950 11-32 weighs in at around 340.
The 11-34 version is a good bit heavier at close to 450.
I'm going to swap my 950 for a 970 whenever new wheel set time rolls around.
XRanger said:
Thanks. The 970 sounds better to me. I think it has an aluminum spider and I need to replace the free hub also so whats the rule on hubs when using an aluminum cassettes versus steel?
The pic above seems to disagree with Eville 140's claim.
Claimed weight of different SRAM cassettes (all in the 11-34 size):
PG-950: 382g
PG-970: 340g
PG-980: 304g
They will all work fine. The biggest nit I have to pick against the lower level SRAM cassettes is that the parts are 'loose' and while this makes cleaning easier to get everything super clean, you have to make sure all the parts/spacers go back together correctly. Not terribly difficult, but a little annoying to me.
As for Shimano, I have personally prematurely trashed three XT cassettes. I bent the 2nd gear cog on two of them and ripped four consecutive teeth from a cog on another. I am done with XT cassettes until major changes are made to them, but I am a good sized clyde. If you are of average size and strength, then XT should work fine for you.
I have had great luck with the LX (CS-M580) and the HG-61 from Shimano among others, just not a fan of XT for large/strong humans. I have also used several SRAM cassettes (950, 970 and 990) with no premature failures.
The SRAM 970 does not have an aluminum spider. See the pic below and you can see the separate cogs in the 'hole'. The 980 is the lowest level SRAM cassette that has an aluminum spider and the spider on the 980 has only the three largest cogs on the spider as opposed to the 990 which has a spider for the six largest cogs. The biggest benefit of an aluminum spider (aside from any weight saved) is that it will prevent damage to an aluminum freehub body from the cogs that are mounted to the spider. Shimano (the brand of the freehub the OP has) doesn't make any aluminum freehub bodies that I know of.
