I have a 2000 Zaskar X that I fully rebuilt years back with a 120mm stem and a 680mm bar (minimum the enve bar could be cut down to and it was close to the stock bars size).
Recently it developed a crack and im seeing most bars now can only be cut down to around 740mm since everything seems to be moving toward wider bars and shorter stems. I picked up a new ENVE M6 which was warranty replaced from the cracked bar and paired it with a shorter 100mm stem (might need some dialing in still). While it feels ok after some initial getting use to it i'm unsure if there is any negatives to doing so on these older bikes? Should I be trying to find bars that can be cut shorter again? Are wider bars/shorter stems better even on older frames like these as long as you're still able to run an 80mm or greater stem?
I must admit whats taking me the longest to get use to is the looks since i've ran 120mm stems on almost everything i've ridden in the past 20 years, but i'll just get use to it if it's actually better.
