Just curious here....why do most small custom framebuilders work almost exclusively with steel and titanium and eschew aluminum? Durability issues?
golden boy said:Just curious here....why do most small custom framebuilders work almost exclusively with steel and titanium and eschew aluminum? Durability issues?
Also Mike Ahrens.SC RockLobster said:you need to talk to Paul at rock lobster cycles. He does a bunch of Aluminum frames. I have 3 myself. he also does scandium, and steel but NO TI. I have a Scandium bike paul built for me in 2002 and it still rides just as good as the others:thumbsup:
man, my experience is quite the oppisite.........{yes, i did work in Al. fab for 4 yrs} .7mm steel burns FAST. Al. is easier on tools, cleans up quick, the tubes are thicker across the board. as per Ti being easy to work with, well..........heff® said:You misread me there. Never said it was a bad material, my frame is aluminum. Works great. Getting old, I need to replace it just for the fatigue lifespan.
What I said is it's difficult to WELD, not ride. A properly done aluminum frame is just fine. But actually building that frame is a different story. Steel and ti are much easier to work with. You have to make an effort to burn through steel........if you sneeze while welding aluminum, you just smoked a tube. The giant companies don't particularly care, they're using precision robots to do the work, and they can afford a certain amount of loss. They're buying in bulk, anyway.
also add Primus Mootry, Spooky & Tsunami cycles........ Steve Garro, Coconino Cycles.coconinocycles said:not true - if done well Al. is a great material. my short list: Rock Lobster, Ventana, 3D, Siren, Ahrens.
I'll add Frank Wadleton aka Frank the Welder to this list.coconinocycles said:also add Primus Mootry, Spooky & Tsunami cycles........ Steve Garro, Coconino Cycles.
